101 - 115 of 115 Posts
Discussion Starter #101
The issue here is not necessarily the OAR. It's the elevated spikes in KR.
Truck drives fine with a less than desirable OAR. It does not while the knock sensors are pegging the max.
Yes that is correct, the poor OAR is just a result of these random knock sensor spikes which we cannot find the root cause of..
Discussion Starter #103
Like Woo said, I see you have aftermarket downpipes. Could those possibly be causing the KR? Did it do this with the stock downpipe?
Unfortunately I never really tracked OAR or KR with the stock ones on, came from a diesel and had lots to learn! It could definitely be related but if so then what is the fix? seems like everyone with downpipes and an exhaust should have this issue then no?
Discussion Starter #105
Just turn down knock sensitivity
Thats likely what were going to do, specially seeing as it didnt even react any differently to e30...
Discussion Starter #107
I was just kidding.
I have seen stock tune trucks see 5 or 6 degrees of knock consistently. So take it with a grain of salt.
If your OAR was basically locked in at +0.50 no matter what you did im sure youd give it a shot too haha
OAR is just an effect due to KR.
The KR spike is what's most noticeable. OAR does make a difference but not anywhere near as noticeable as a 6+ KR spike.
KR will spike in a split second under throttle but takes significantly loger to fall back down. You can let off the throttle if you don't want to wait but then OAR readjusts.
Someone needs to be the guinne pig and replace their knock sensors to see if that fixes the issue. Its the only thing I haven't tried yet. They very could even be loose causing false readings but they are super crappy to get to...
  1. Going back to full stock had no impact on my KR activity.
Here are some really good articles that stratified tuning has written up on Ford ecoboost knock and OAR.
I realize it's not directly related to our 3.5's but I wonder how much detail our tuners can see in regards to our knock sensors? Can they see individual cylinder knock? That would be hugely beneficial in trouble shooting.
Yup, your tuner can change your tune to individual Knock, it’s just one setting. Obviously, you would have to add the correct PIDs to your config file. I have noticed better performance with my truck on individual vs. Global.
When i played around with my tune i just changed how much load i needed to affect the OAR. The KR and OAR still responded in the same way but I made it so that OAR only changed when load was >=0.8. This made mine a lot less volatile but there did not appear to be any negative consequences as the KR still functioned normally.
I think in @looqw situation, he was still seeing the knock under a higher load then .8. I offered up this solution as one found to work for others, but it didn't really seem like it would be a resolution for him.
Discussion Starter #114
@Blown F-150 is correct, I saw the high KR on part throttle all the way to 1.2 on occasion so the under .8 being turned down or off unfortunately would not make the difference in my situation.
The most success we have had is when @Boostking turned the tune over to individual knock and atleast the one problem cylinder does not bring down the rest of them, as stated previously in the thread cylinder 3 is the culprit and is almost permanently showing bad KR numbers (negative on individual knock config). I don’t seem to be the first with one cylinder being the cause but once again no one has ever seemed to find a real resolution aside from tuning around it which we likely will have too.
Yes. My truck reads and displays knock per cylinder, and apparently each truck can be programmed to do it either way. I've had tunes that set my truck to do it either way.
Edit...I see that was covered now. Lol
It's not always this way, but I oftentimes have cylinder 6 pegging the knock sensor when the rest are fine. Sometimes it's not that one though.
