61 - 80 of 100 Posts
Very good for the crap Density Altitudes right now in AZ . Currently 4746 ft as i write this. Take a few tenths off that when we get that cool morning air starting here pretty soon .
Discussion Starter #63
With an IC, downpipes and intake and good air this winter I think an 11 is definitely possible in this which is CRAZY.
That mustang sounded way faster than it was lol
Great run.
i think it may take more than that those mods suprisingly didnt add too much to an already well tuned gen 2 polar opposite of my gen 1 f150
Discussion Starter #66
We're down around 10lbs of max flow on the turbos and the manifold temps are seeing around 160 at a full pull and ECU is pulling timing. DA was around 5500 that night as well.
There's about another 70lbs in it plus if I can get down around 1K DA that's more than a second of ET available. I'll pull the middle row captains chars and spare for another 300lbs/.3 in the 1/4 as well.
Plans are always nice, we'll see if I can put it into practice, an 11 second Navigator would be HILARIOUS. :)
Discussion Starter #67
70HP not 70lbs, can't find the edit button :)
Discussion Starter #69
DA correction shows [email protected] for the run that night.... Damn **** air in Phoenix
Discussion Starter #70
Navigator doing tow duties for my V and new trailer. New water to air intercooler getting welded up this week as well.
Sent from my Pixel 3 XL using Tapatalk
Discussion Starter #71
Time for some goodies, air to water was a no go, back to using that on the tremor. Going to install this weekend, have to get ready for SCT Phoenix
How so? The website only shows 18+. and their power claims are based off their tune. I imagine the elbow down at the turbo curve may hurt a little but I don't know about 20hp. Take your intake tubes complete off and test with open turbo, lol.
Adam showed some airflow gains of 5#/min, with just the tube swap. I'm not saying everyone would see the same results, but even 2-3#'s would be sweet.
Discussion Starter #77
I'll take everything I can get, need to be 12.0 for SCT Phoenix competition 10/18 :)
I would think the turbos would need to be at or near max flow to see substantial gains from the tubes.
Its the same as with a CAI. All you are doing is increasing the pressure/density going into the compressor. If you increase the density going in, then you can get more mass flow going out. If the turbos are not already maxed out though, then they are going to magically flow more.
Discussion Starter #79
We're 10lb per min away from max currently, need to do boost activated cutout also. Intercooler is mandated as manifold temps around 160+ to 170
A 12.0? WTF? I know you're running e85 and have the bigger HO turbos but that thing is heavier than Tremor. My only goal is the run 12.5 on straight 93. Not a race car but still disappointing to know a Navigator could be quicker, although not a 93 tune vs 93 tune though.
Good luck.
