141 - 155 of 155 Posts
Looks like the weight is balanced really well looking at the numbers. Ya'll are making me want to hook up and head out!
They're making me want to quit being a tow-weeny and go fetch a mansion on wheels.
Down at Wind Creek casino at Atmore Al. for a few days. First time I’ve driven the TT with tune. ( almost 700 miles😂) finally got the fault problem solved I think (changed to SCT Livewire TS) Running 91 per/tow V2 on 93 gas. What a difference !!!!!!!!! Hills are of no concern, well at least these ant hills down here LOL. Finally got her leveled. 39 1/2 on front and back and within 3/4” from front and back on TT at 35 lbs in air bags. I also lowered one bolt on hitch. Water Temp never went above 220 and xmsn 203, CAC 5-10 above air temp on highway. Also dropped by CAT scales 15780 total with 7780 on TT axles 🤦‍♂️
Good to hear you got it leveled! I need to find some level ground this year to see exactly where I'm sitting.
I picked up a 1 1/4 in ratcheting wrench last fall. Way better for tightening the chains on the Andersen that using a ratchet or breaker bar and socket.
Thanks everyone for the comments! I’m still not out of the woods :( I still have to balance out the sway and bounce on bumps. I can get one acceptable but not both at same time. 9100 on TT and 1320 on hitch puts it at around 15% @Kinguni i use a ratchet torque wrench to tighten or loosen the Anderson adjustment nut, just put it to max. Now it’s Time to loose my money to the one arm bandits 🤬 LOL
That's what I used to do. Ratcheting wrench is much better. Good luck!
May I ask how mu
may I ask how much does your red bushing bulge if any? And does your truck bounce (buck) more if you over tighten or less?
May I ask how mu
You know, I haven't really paid attention to how much it bulges. Camping season is still over 3 months away here so I can tell you then lol! As for the bucking, I haven't really noticed it changing with tightening, and it's much less that with other weight distribution hitches I've used. I think the Timbrens really help in that regard too. Still, I will go out of my way to avoid a couple of highways around here.
Ecoboost towing Ecoboost...
What are you up to? :)
My brother popped his 3.5 - towing it back to his place nearly 3 hours away so he can clean it out before the repo man shows up.
Just hauling a small washer to storage until I get a chance to rebuild it to sell! Weight is only around 900lbs I’d say.
