1 - 9 of 9 Posts
I have a 2013 fx4, and the other day I noticed there is a plastic guard covering the top 6 rows of the intercooler. Anyone have any idea why Ford would put this on there?
Its a bandaid for the condensation issue that ford is having with their intercoolers. The CAC (Cold Air Charger) is so efficient that it actually ( in highly humid situations) can turn the air back to dew point. That shroud is supposed to fix it.
Apprently it doesnt fix the issue though because people with that plastic cover have experienced the issue.
My truck was built in August 2013 and came with the plastic shield that covers the top / front area of the intercooler (CAC). Hoping for the best.
my truck has it installed and yes it covers about the top 1/4 of the intercooler
i dont know why there isnt a drain welded into the bottom of it and i would bet during startup and high idle if a solinoid valve was opened it would purge any moisture
it would probably only need to be done once a day which your cold startup each day would cover.
with all the computer controls and technology we have these days this would be simple to control.
Thanks for the info. I was about to remove it. Seems like a horrible answer to the condensation issue tho.
It is certainly aband aid solution. If I had $900, is be going aftermarket, as they're are much more efficient
im not in the market to replace the intercooler but i would seriously wonder how a bigger more efficient intercooler would not cause even more condensation !
after all i am only using 3/4 of my stock one because air cannot flow through the top of it.
Discussion Starter #8
was wondering the same thing
I found a great video on this!
Get rid of that cover!
1 - 9 of 9 Posts
