And there is always the option to disable updates (unless a future update removes that option).
Just wrap it in tinfoil. Oh wait, it's an aluminum body so it already is...Disabling updates in Sync4, only disables updates that require the vehicle to be inoperable for a period of time.
It does not prohibit the kind of updates that are currently being pushed out.
Things like Telematics, Gateway, and APIM are going to go through unless either the file download fails, or the battery voltage SOC is prohibitively low.
You can disconnect the Telematic C Module though. (behind the passenger rear seat)
That'll certainly stop it since the truck would no longer be able to communicate with the servers.
I can now say I learned something new today! Thanks for that insight.Disabling updates in Sync4, only disables updates that require the vehicle to be inoperable for a period of time.
My truck is fairly simple. It doesn't have Blue Cruise, or adaptive cruise control, etc. Doesn't have front sensors either.Ford's OTA is either feast or famine.
But currently it's in feast mode and updates are flowing.
4.2.2 a few days back
4.2.3 Saturday
4.2.4 today
Rumors are this is prepping for the next version of Lane Keeping and Adaptive Cruise /Bluecruise that the 2023 Mach-E has. If so, that'll be awesome.
So you bought "the kit" and it included the trailer side harness?Sorry for the sidetrack but is the “ultimate trailer tow system w/ pro trailer assist”?
I have the TPMS kit, which includes all the stuff for the trailer camera and obviously the tpms sensors for the trailer and yaw sensor, also a harness I may need. Apparently that’s a requirement, but I don’t see a listing for that anywhere. I do have the 360° camera, backup cameras, and pro trailer assist.
I think that’s all I need? According to other forums that everything people purchased. My plug that attaches to the trailer connector plug has 8 wires so I believe that good for the yaw sensor?
Yes it’s the LC3Z1A189ASo you bought "the kit" and it included the trailer side harness?
Is it LC3Z1A189A
And your truck has the 12-pin receptacle below the 7-pin standard trailer receptacle? Or do you need to install that from the kit?
Some 2021 F150's came with the correct hitch receptacles for this setup from the factory. (my Plat Powerboost did. Had the Yaw sensor too)
I don't remember all the details but it may require you to do some wiring on your truck as well. And you might have to do some Forscan editing?
You should already have all the different trailer camera views available in Sync4 when you are connected to a trailer. Have you checked that yet?
Good solution! They are probably less costly than the tent company’s strap covers AND you have a more versatile item to use for other things.Harbor Freight moving blankets paint protection 🎨
