So I have a 2015 F150 screw with the 3.5. 6" lift on 37s with under body armor and rock sliders welded to the frame.
I routinely take my truck through trails and into environments that FoMoCo probably never intended this truck to go to and be put through.
Here is the really weird issue that maybe one of you have experienced or know of.
I will be in either 4H or 4L, and chewing my way over an obstacle, whether that's a group of rocks, a rock ledge, or in todays case extremely deep sand on an incline. I was in M2 with the locker engaged, and was steadily chewing through the sand and climbing up a very soft section of a hill climb out at the dunes here in Vegas, and out of the blue the truck just stops cold turkey. No wrench light, no pop up info box saying check this or that, no chime, no CeL, nada. I could press the accelerator to the floor and the motor will not come off idle. I literally have to switch back to N, rotate selector switch to 2H, shift to P, then back to N and back to 4H or 4L to get throttle response back. This has happened to me several times before in the past and its always the same solution, and "almost" always the same scenario that causes this issue. High wheel speed, low vehicle speed (I:E; clawing up a rock ledge, scrabbling up a gravely hill climb, chewing through soft sand) seems to make my truck go into some sort of protect mode. I am tuned by MPT on the 91 PR-X so Idk if this is a torque management issue or not, but shortly after my truck did this, my friends 2020 2.7 powered screw F150 attempted the same hill and despite him running 35s and being stuck in my ruts I made, he was under full throttle significantly longer than me and now once did his truck ever go into a protect mode. Our other buddy has a 18 screw 5.0 F150 and his truck was cutting power on him, but nothing like my scenario, and he is not tuned at all.
I have no ideas other than perhaps torque management? Nothing I can think of to google this issue comes up with any viable situations and solutions that others may have found or experienced. I've even called dealerships and talked to techs, parts guys, shop leads, master techs, and not one of them have any idea wtf is going on. I've never experienced anything like this in my 14 Fx4. I was stuck in a mud hole in that thing and had the throttle pegged to the limiter with the 5.0 in it, and never once did it go into any sort of "protect" mode.
Strangest thing, again, is the absence of any pop up warning box, or code, or any chime of any sort that would alert you to an issue.
Is my possessed?
Is my possessed?
