I was wonder what were some of the pros/cons of removing the resonator? I called Ford and they said not to do it because of emissions. I haven't read anywhere about those concerns. Thanks for the help
So what would replace it, a resonator delete or a catback?It's between muffler & res
Sent from my silver iPad Air 1 in a http://www.red.org/en/ smart case using an app called Tapatalky
It would be replaced with a cat back system. I believe 2canches is just saying that it is beneficial to remove the flex pipe with the resonator.So its not part of the catback or resonator pipe? Just a res delete or just a catback that doesn't have the resonator section won't replace it?
Its not built yet. I still have my raptor. Ecoboost coming in the spring(April)Yes a cutback would replace it.
It goes
Down pipes
Resonator
Flex pipe
Muffler
Have a look under your truck if weather conditions let you
Thank you, OK so now I see that flex pipe is actually welded to the muffler. So any cat back system will get rid of it but just an off the shelf res delete won't. so a straight pipe would be needed to be welded on if the stock cat back is kept.View attachment 30333 borrowed from Google
