41 - 48 of 48 Posts
Wow, there really is a difference between the pipe in and out of the muffler.
Your right, there seems to be a pretty big difference!
The stock down pipes where it y's into 1 pipe is that 3" or 2.5" ? I know the res pipe is 2.5" but what about the y pipe?
Going by memory (it's too cold to crawl under and verify) ... but the stock Down Pipes have 2.5" on each bank until the Y. I am uncertain about the diameter of the Y itself, but it wouldn't surprise me if it was 2.5" also, as some aftermarket downpipes advertise they are still 2.5" on the pipes from the banks but 3" after they Y. So I suspect the OEM Y is only 2.5".
That is why I chose the Full Race DP. The Full Race are a full 3" on each bank's pipe as well as the Y. Also, Full Race have one of the best looking Y's I've seen (other than maybe Kooks). It was the Y pipe that sold me on the Full Race over the other DPs. They are also made out of T321 Stainless Steel (others are made out of a lesser grade of stainless .... others are not stainless at all ... but you could have them Ceramic Coated to help reduce rusting and help retain heat too).
Reactions: NickPic83
I am on my third exhaust setup as of now, I did them in steps. First was stock, it had to go for the performance benefits. So I moved to a 3" straight pipe from the Y back, this was obviously overly obnoxious. Next i followed by splicing in a 3" in/3" out Magnaflow muffler, this got rid of the dorkiness for the exhaust but still had a very high pitch at 3/4 to WOT. Currently I have an 18" long 3" diameter straight-through resonator. So far the best sound. I recently installed an AFE twin tube CAI, now the truck is coming to life.
Are you tuned yet?
Just a quick tip for those installing the oem resonator delete.....to remove the resonator...twist! Work it left n right to get it off.....a bfh wouldn't beat it off...then I twisted it and pulled it off by hand. I'll let ya know about the sound this afternoon
41 - 48 of 48 Posts
