You can get far more power than you or your block could ever withstand by using 1 or 2 turbos.
compound boost is used in some race applications. That incorporates a S/C and turbos. This is typically used in larger turbo applications as the S/C provides the kick down low to enter the higher RPMs necessary for a larger turbo. Nitrous is used in the same method.
