1 - 14 of 14 Posts
So as we all know the factory Traction Control and Roll Stability Control never really lets you have fun. Even in the "off" position it intervenes with a good time.
So my question is this-
Are there any tunes available that fix this?
If not has anyone figured out a way around it?
Is really like to be able to do a donut or two this winter.........
There's not a way for the tune to disengage traction control or advancetrac. At least there wasn't a possibility before when I ahead my mustang...
I've had this option through the tuner on past vehicles, but idk if you can on the eco.
Touché. I stand corrected.
If they can adjust shift strategies I'd imagine they have access to torque/traction management as well.
Discussion Starter · #6 ·
If so it'd be enough for me to throw my warranty out the window.
It's a good safety feature but when I turn it off I want it to be off.
Let me wreck my truck if I want to......
Hold the traction control button Dow like 5 seconds and it will cut off the stability control and traction control for temporary fun.
Discussion Starter · #8 ·
I know that.
Everyone knows that. I want it OFF. No interference with my shenanigans!
Discussion Starter · #9 ·
Double post.....
No way to permanently cut it off - I would think its more of a safety issue to cut it off permanently IMO
I'm curious to see if the F150 can be retrofitted with the "off road mode" that the raptor has. I'm looking into the controller and aux switch panel with the built in button.
Same here .... Let me know if ya figure that out
From what I'm seeing it also adjust the throttle curve when the offroad mode is enabled. This leads me to believe that the raptor may have an entirely different PCM than we do, and if so I doubt we will be able to run this mod...
If only they made an eb raptor...
Reactions: Grim Reaper
1 - 14 of 14 Posts
