1 - 7 of 7 Posts
RDP Store is proud to introduce ReadyLIFT suspension full product range for your F150 and Raptors, old and new alike. You will not find better pricing and knowledge then at RDP Store. Plus free shipping and freight on orders big and small. Also to help answer you question here is an all important tire sizing guide. PM us to confirm your desired tire fittment for you ReadLIFT part number you are interested in.
RDP Store - ReadyLift
The Maximum tire size information provided in this vehicle/kit chart is meant to be a reference guide. All Maximum tire sizes listed are the largest possible tire that will fit the vehicle with the respective ReadyLift kit installed. All vehicles are slightly different and all tires are slightly different in actual advertised sizes and design. ReadyLift is not responsible for installation of tires that rub or do not fit due to a wide range of diverse variances that can occur from vehicle to vehicle and tire to tire. This guide is not meant to provide recommended tire sizes but rather the Maximum tire that will fit under most circumstances
Offset - Backspacing
The offset of a wheel is the distance from its hub mounting surface to the centerline of the wheel. The offset can be one of three types (measured in millimeters).* Wheel backspacing is the distance from the hub mounting surface to the inside wheel lip (back side of the wheel) and is usually measured in inches. When chosing wheels it is important to pay attention to the backspacing. A common "offset" for example is +12mm or -12mm. In this example a +12mm wheel would be a positive offset wheel and a -12mm wheel would be a negative offset wheel. In this case "0" is the centerline of the wheel which means a +12mm offset is a wheel with a hub mounting surface 12mm (roughly just over half and inch) further outwards toward the front of the wheel. Think front wheel drive car wheels for reference. A wheel with a -12mm offset would have a hub mounting surface 12mm inside of the wheel centerline, or closer to the back side of the wheel lip. This type of wheel usually has a "deep" look as compared to a zero or positive offset wheel.
Most all factory truck wheels are positive offset to one degree or another.
Installing a wheel with less rear of wheel backspacing than the factory wheel results in the wheel sticking out further than the stock wheel did.
wheel offset, wheel backspacing, wheel size
ReadyLIFT Wheel Offset conversion chart
Zero Offset
The hub mounting surface is even with the centerline of the wheel.
Positive
The hub mounting surface is toward the front or wheel side of the wheel. Positive offset wheels are generally found on front wheel drive cars and newer rear drive cars.
Negative
The hub mounting surface is toward the back or brake side of the wheels centerline. "Deep dish" wheels are typically a negative offset.
If the offset of the wheel is not correct for the car, the handling can be adversely affected. When the width of the wheel changes, the offset also changes numerically. If the offset were to stay the same while you added width, the additional width would be split evenly between the inside and outside. For most cars, this won't work correctly. We have test fitted thousands of different vehicles for proper fitment. Our extensive database allows our sales staff to offer you the perfect fit for your vehicle.
*Backspacing, similar to offset, is the distance from the hub mounting surface to the inside lip of the wheel (measured in inches).
Discussion Starter · #2 ·
At RDP Store you simply Find it Choose it and Save, Simply search our online Store at Performance Parts Camaro Challenger Mustang SRT8 Corvette find the part your looking for, put it in your shopping cart and pm us for a promo code and we will make you a deal to blow the others away. Top this off with Free Shipping to the Lower 48 States and Cost Price Shipping anywhere else in the World and your on the Way to Huge Savings and Great Performance Parts, pm us here for more details or give us a call on 440 358 5500 or 440 251 8571
Discussion Starter · #3 ·
Here at RDP Store we don't bump just to bump the thread. WE on a daily basis upload new products everyday. So many new products to advertise individually we just can keep up. So don't for get to check us out, there is always something new at RDP Store and always a promo code to help you forum members to save big. Take a browse and PM us today if you see anything that peaks your interest and if you dont let us know and we will find it for you.
Discussion Starter · #4 ·
Discussion Starter · #5 ·
Discussion Starter · #6 ·
Discussion Starter · #7 ·
1 - 7 of 7 Posts
