Rear Diff oil
3 reading
52K views 14 replies 10 participants last post by  Nicklaus
#1 ·
Hey all,
I'm about to change out oil in rear diff. Question is, do I change to 75/140 like I'm seeing in videos?
Or stick with the 75/85 per owners manual? One dealer says stay with 75/85.
Oh, mines a 18 with reg axel.
Thanks for any light on this.
Reactions: Vic Denim
#3 ·
Mine came with 75w85. I changed it to 75w140 after 20 miles or so. Same axle as ford has used for years with a 75w140 spec magically needs a lighter oil all of a sudden.
Reactions: snakebitten
#5 ·
I am only assuming here…but the lighter oil would reduce drag in the rear end helping to improve fuel mileage which is a major selling point of the Ecoboost engined trucks. Heavier oils while providing more shock protection would increase drag and reduce fuel mileage.
I have to believe that any mileage decrease would be negligible unless you’re trying to hypermile your truck. I would opt for the thicker fluid if you were going to any serious drivetrain shock inducing maneuvers.
#6 ·
Isn't this another instance where Ford changed their "recommendations" for fluid during the ownership of the product?
In other words, on the day you acquired the vehicle, Ford recommended a specific viscosity, and then later changed the recommendation for the viscosity?
I'm only pointing out that this does happen, and if nothing else it undermines the theory that Fords recommendations are unequivocally the best choice no matter what. Afterall, they actually change their mind at times.
There's a REASON Ford (or any manufacturer) would do that.
#11 ·
Since this is a rear diff thread I have a side question. I put the Ford performance LSD for the super 8.8 in my 2017 and I keep getting audible noise and I can feel the clutches slipping when turning but it's often not smooth slipping, more of a bind/slip/bind/slip kinda deal.
I put amsoil severe gear 75w-90 with the amslip sliplock friction modifier about 15000 miles ago. Should I be using something else or is this normal operation for an LSD?
I've never used a clutch type LSD before so I have no personal comparison.
#12 ·
I put the 75w140 in because I regularly tow 7500 lbs with the truck loaded to the max door sticker weight. I also had 4 bottles of 75w140 left over from my 2009 F150. Same 9.75 axle.
Add another bottle of friction modifier if your differential clutches are chattering. If that doesn't help, you may have an actual problem. Ford XL-3 friction modifier is an option.
#13 ·
Are you using the same LSD just on the 9.75 axel?
