I had Recon send me two resistors to resolve hyerplash issues with my LED Taillights. I'm not sure how to connect them. Any help would be appreciated. See attached pictures for my LED tail connection, and the resistor they sent me.
How many resistors did you order? You will need 4 of them and you want to install them on the wire that is for the brake lights. All it does is "put a load" on the flash circuit to make them flash slower.
Connected one on each side, pulled the negative battery cable for 30 minutes, and continue to have hyperflash issues. Fortunately it happens only occasionally now and not constantly.
The rapid flash is a "bulb out" indication. I wonder if the dealer could turn that feature off in the PCM.
I know on the super duty trucks there is an option for that to be turned off in the PCM.
Sent from my Siri instructed iPhone using Tapatalk
