Roush Boost Gauge installed
11K views 34 replies 9 participants last post by  TOOLOUD
Just FYI, the Glowshift Elite I installed has the peak value. Although I must say I never look at the peak, I use the boost gauge as more of a load indicator. The high the boost the more loaded up the engine is. Although the fuel economy screen does that too.
I bought the column pod mount. Just trying to figure out the best way to run the vac line so it doesn't get pinched by the tilt column. Thanks for the info on fuse 29. I read another post that someone used that to tap into.
There is a small nipple on the main grommet on the drivers side. I just punched a small hole through that and ran the hose.
Ok, ya I zip tied mine out of the way, zero issues.
Ok, I just pulled off the side cover to get access to behind the wheel. It would allow some access to the pillar also
But I also could be not fully understanding what you are trying to do.
Rob he has a steering column mount!
Ok I understand now, I figured by column he meant pillar. I haven't seen a column mount, any pics?
