Hey People. Thanks for the add. Trying to figure out which turbo is blowing all the smoke. I have dropped the Y pipe which has all 4 O2 sensors in it. Can I run the engine with no sensors to see which turbo is causing the problem. I thought it was the drivers side because of wet joints in the exhaust on that side. I changed that turbo, coolant lines and connectors, and oil supply line and filter. I also cleaned intercooler, throttle body and all tubes. I put it all back together and it still smokes, but not nearly as bad. Don't want to change passenger side if both are smoking. Thanks for input!
