1 - 4 of 4 Posts
Would like to see turbo boost on my 2013 F150SCREW and forgot I had a Scan Guage II that I use on my motor home. Looked at the xguage but can only find turbo listing under diesel. Does anyone know if it will work on the ecoboost and if so do you know the code?
Depending on how old your unit is you may have to send it to Scangauge for a free software update. You can use it to display boost pressure with the current software. You can also read the MAP sensor but you have to do a little math to know boost pressure from that. You'll have to subtract atmospheric pressure from what the readout shows to know your boost
I run through all the gauges and could not find boost listed. I did see MAP listed though
Finally emailed Scan Gauge, under advanced menu you can change MAP to Boost.
1 - 4 of 4 Posts
