Shake Above 65 mph
1 reading
18K views 14 replies 8 participants last post by  Boatwaco
HI all. Original owner of a 2015, Super Crew. A shake since day one that was very much like a tire balance. I originally passed this off as possibly road surfaces etc. as it would come and go. I am on my 4th set of tires including OEM, and none has corrected the problem. This start around 70mph, again was very mild and would come and go. This has gotten worse over time and under warranty my current tires were due for rotate and balance, problem continued. I then took my truck in to Less Schwab, complementary balance, and I did watch them. The report was all good, one very minor weight change on one tire, but again, the problem continues as of driving on the freeway yesterday. All report suspension okay, rotors are good, no rim damage etc. etc. All I can say is there seems to always be some issue with this truck, which is very well maintained and taken care of. Most shops these days if there isn't a code or light to tell them what "part" to replace are lost otherwise. I will likely end up doing the more in depth troubleshooting myself. Just on here to see if this is yet another inherent issue with these trucks and a source or cause of this shake/vibration has been identified by anyone. I like my truck, but dang if all the issues isn't getting old!
