1 - 10 of 10 Posts
I am debating two things the tire width and load rating. As far as width my new wheels are 20x10 and have a -19 offset and 4.75 BS so I am concerned that the 305/55 will rub vs the 285/55. The other issue is should I get the LT285/55/20 due to the extra load rating (LT tire)?
Nitto Terra Grapplers
LT285/55/20 (W 11.73 DIA 32.28 Load 3305)
305/55/20 (W 12.40 DIA 33.19 Load 3086)
Would the dia and width between these two really make that much difference in appearance or would it just make sense to go with the 285's. I have 6,000lb boat and trailer that I will pull a lot in the summer months. BTW I am adding a 2.0 or 2.5" leveling kit.
Thanks and Happy Turkey Day!
Discussion Starter #2
Ok so now I see that there is also an LT305/55/20 so the load is really not a problem between the two. The question is will the 305's rub with this crazy offset and if so will it be an easy trim fix or should I just go with the 285's or will they require a little trimming too? If so, I would rather have the taller wider tire for the look/stance.
6k lbs. A LT tire would be better as you can air up the tire higher whole towing. If it's only once or twice a year. Don't bother.
I have 305/45/22 Terra grapplers and only tow heavy loads 2x a year at most.
From a load perspective, I have the non-LT 305/55R20 Terra Grappler and pull a 5800lb wake boat regularly without issue. Mine are on stock wheels though.
Thanks for the info guys.
I was lookin at 325/60/18s on stock wheels. Come as an LT. Stock tires 58lbs. These are 72lbs. Woof....
I ran a set of nittos one time. They are great when new, but get loud and slippery as they wear...
I ran a set of nittos one time. They are great when new, but get loud and slippery as they wear... Sent from my SCH-I545 using Tapatalk
My buddy is a district manager for nitto.... Ummm they wore. Must be a defect! Thanks for a new set ;-)
Very nice.
That's one of the major negative trade offs. Being unsprung weight is about 10 times more detrimental to performance when compared to sprung. :/
1 - 10 of 10 Posts
