Since selling my old Tacoma I am starting a build thread for my Furd. It's a 2012 Furd F150 3.5L Ecoboost. I bought it with about 94,000 miles on it and it had a leveling kit and 305/55/20 K02's.
So far I put a tune on it, upgraded the brakes, added an AFE charge pipe, AFE Stage 2 Intake, upgraded the headlights and fog lights and put in a spray in bed liner. It'll being going to see @JerryTX very soon to get some well needed upgrades
Edit:
It originally went up to Tifosi Performance around October to get GT turbos, CRP ported manifolds, CPE Intercooler, Tubrosmart BOV, Full Race Catted DPs and an Intake. I added all this stuff because it was either needing replacement or going out and needed to be replaced soon anyway. Truck was running amazing until the rings let go around 120k miles in February because of carbon build up. Thanks GDI....
So now it's in the process of having a brand new built block with ported heads and EFR Turbos put on from RMB Motorworks.
Current mods are as follows:
Exterior:
BFG K02's 305/55/20
Custom Retrofit Headlights
Stubby Antenna
DIY Bedliner
Moriomoto XB LED Fogs
Interior:
LED Interior Lighting
Proclip Phone Mount
Motor:
RMB Motorworks Stage 2 Short Block
• Cylinder Block - Brand new Ford OEM bare block with a 92.50mm Stock Bore (Closed Deck)
• Pistons - RMB-JE 92.75mm FSR Forged Pistons, Custom Ringset, .210" Steel Pins, Clips, (Coated Skirts and Offset Wrist Pins)
• RMB Spec Gold Ceramic Piston Coating
• Connecting Rods - Callies Compstar H-Beams with ARP 2000 Rod Bolts
• ARP 2000 Headstuds
• Rod / Main Bearings - King XP Bearings
• Crankshaft - New Ford Gen2 Raptor Forged 2017+ Crankshaft
• Main Bolts - Standard OEM 6 Bolt Mains
• Compression Ratio: 10.0:1 STD Compression Ratio with STD .040" thickness head gasket
Pocket Port-R Heads with conical spring kit, with Ti Retainers and locks and custom valves.
XDI-35 HPFP
Spec C Cam Lobe to increase HPFP by 25%
Full Race- RMB EFR Twin Turbo Kit: • BRMS Crimped Racing hose upgraded
• PTP Turbine Blankets
• Charge pipes
• Hot Pipes
• EFR Manifolds
• Turbine Blankets • EFR 71/63 T25 single scroll turbins with T25 in and 3" outlet to a true 3+ pipe
• Black ceramic coated compressor housings
• Black ceramic coat turbine housing upgrade for the forged case center section made form aluminum
• Upgraded forged aluminum light weight turbo center-section
Turbo Smart IWG-75 Waste Gates with 14LB Springs (B1 Single Scroll Housing (Double 7lb spring))
Full Race V2 Intercooler
Full Race V2 Radiator
Radium Dual Catch Can
Custom Blue Painted Valve Covers
Trans:
Stock
Exhaust:
Full Race exhaust with resi
Suspension:
Rancho XL9000 Rear Shocks
Fox 2.0 Coilovers
Moog Upgraded Sway Bar Endlinks and Bushings
Plans:
Suspension:
Front:
Raptor LCA, Axle, Sway Bar
Aftermarket UCA, outer tie rod
King 3.0 Shock
Rear:
King 3.0 Shock
Deaver Leaf Springs
Bumpstop kit with King Bumps
^^^More details to follow^^^
Trans:
Upgraded Torque Converter
Billet Input Shaft
Stage 2 Shift Kit
Upgraded Clutches
Exterior:
Fiberwerx front fenders
Fiberwerx bedsides
Raptor rear end with axles
RPG Rocksliders
RPG Raceline front and rear bumpers
Interior:
Upgraded audio
Lowrance HDS-7
Icom Chase Package
Edit:
Exterior:
BFG K02's 305/55/20
Stubby Antenna
DIY Bedliner
Interior:
Proclip Phone Mount
Motor:
XDI-35 HPFP
• Charge pipes
• Hot Pipes
• EFR Manifolds
Trans:
Stock
Exhaust:
Suspension:
Fox 2.0 Coilovers
Plans:
Suspension:
Front:
King 3.0 Shock
Rear:
King 3.0 Shock
Deaver Leaf Springs
Trans:
Billet Input Shaft
Stage 2 Shift Kit
Upgraded Clutches
Exterior:
Fiberwerx bedsides
RPG Rocksliders
Interior:
Upgraded audio
Lowrance HDS-7
Icom Chase Package
