Don't over-tighten it like my father didThat's ingenious 🧐
Oh yea I stop when I cant turn anymore but do go at it like hulk on the short bus.Don't over-tighten it like my father did![]()
The plastic valve covers can't handle much torque, and there's an o-ring on the fitting so it seals without hulk strength.
Wanted the guage for my ownself. Yes I know the handheld could do it but this is a cool guage to me.Why do you need a wideband gauge? We have that built into our facotry o2 sensor and can monitor on tuner.
Also why are you looking in Excel? Look at the graphs, way easier to review and watch while you're driving.
Circle d is who i used for my transmission. They are top notch but expensive.
Loading the tune up now and going out shortlyMake sure all your pipes are connected tightly cause **** is about to get real.
Let’s see what this does. Watch the boost. I don’t want to see more than about 22 psi right now.
We're gonna find out😂22 on those top mount EFR's
What is that compared to say Gen2 oem in lbs/min comparison?
That's gotta be packing a punch, no?
Man it's just so much cheaper to drop it vs buying new lifted suspension dollar for dollarFor the same reason towm8r is being tormented?
Seems it's contagious
I am not sure what you're doing. You can load a file to your SCT that will data log without laptop(1 run at a time) or you can just run laptop. It will show you chart and gauges when you open the SCT software and "connect" to vehicle.Wanted the guage for my ownself. Yes I know the handheld could do it but this is a cool guage to me.
I'm use to looking at Excel sheets and I'm just showing numbers for a specific point. Also, how do I do graphs?
Yea they are THE place to go for trans rebuilds and I can drop it off to them with it in the truck
Ah ok. The only thing that was new to me was the "connect" to vehicle. I'll have to play with it but having a laptop in the truck would be tough without a mount.I am not sure what you're doing. You can load a file to your SCT that will data log without laptop(1 run at a time) or you can just run laptop. It will show you chart and gauges when you open the SCT software and "connect" to vehicle.
Then you can see lamda on each bank. I would watch that, fuel rail pressure and knock. If those are all solid, you're doing pretty good
You just put laptop on passenger seat.Ah ok. The only thing that was new to me was the "connect" to vehicle. I'll have to play with it but having a laptop in the truck would be tough without a mount.
I watch fuel rail pressure and knock on my sct device now so should be good there. I want to do a 3 pod pillar with ethonal, fuel pressure at the regulator and oil pressure.
