1 - 20 of 52 Posts
When are y'all changing plugs. I've changed them once already at 25k and now I'm at 38k. If y'all are tuned do you change them more frequently?
I had to adjust my stock ones twice now. I am sitting at 28,XXX miles on a 2012 EB tuned, and this afternoon actually, I will be installing a set of NGK's. Hopefully they will have better spark and last longer then 10k miles!
About like Carlos, I don't trust them more than 10--12K miles.
I have around 13k on mine, and about ready to change. I can feel a very slight rough idle at times. Also very cheap and easy.
I think somewhere between 10-15k miles if you're tuned seems to be a sweet spot.
It's somewhat ridiculous, but it's cheap, easy and makes it run better.
They doubled in price due to all ecoboost owners changing them.
Mine haven't been done as far as I know. Planning on doing them in the spring. 38k miles currently.
Just did mine at 8300 miles. Truck sat at the dealer for over a year before I came along and bought it. Changed the boots at the same time. Idles way better than before. Gapped to .030 completely stock except a drop-in aem dry filter (if that even matters), catch can and a boost gauge. No hole in my cac.
I recommend no wider than .028 stock or tuned. I lean toward .025-.026, I find it idles a bit better than the wider gap.
I agree with Bruce. My truck prefers .025.
.022 for me but I would recommend .028 if tuned.
Yes, for anyone running more than "simple bolt-ons" .... tighter is better.
1 - 20 of 52 Posts
