Regarding TSB on humidity issue. I had at 70K experienced that misfire issue with NO Codes . Went to Ford a few times to check issue. Finally got the Intercooler updated only to have the same problem occuring. The problem is when accelerating under heavy throttle no payload trans shifts to 2nd gear & sputters to 6000rpm shifts & sputters again .
I have taken tech for a ride with code reader in truck while testing but no codes are thrown but truck sputters. Once while sputtering (no tech in truck at time) trick had NO POWER foot to floor truck bareley made it up a hill, took foot off gas cruised for a minute then everything was fine except sputtering. Ford has replaced plugs , Spark plug boots cost of $171.00, still have the problem. Am now at 103000 K not fixed. Going in once again to Ford. I have talked to loyalty dept ,ford techs & they are all stumped. Anybody else with same issues?
