1 - 4 of 4 Posts
2014 super crew eco boost. It seems to stay in 2wd for a bit then once I stop and start back going I can hear it roaring because the 4wd is engaged. If I stop and turn the switch to 4wd hi and then back to 2wd it’ll disengage until I stop again
any ideas?
I believe it’s just the front axles turning, can’t tell which side. I’m having to switch it into 4hi and then back to 2wd to get it to stop. No noise
IIRC that's the IWE. I had the same problem and to eliminate the noise (but not the problem) I would also shift into 4HI and then back out.
1 - 4 of 4 Posts
