181 - 200 of 217 Posts
Discussion starter · #182 ·
Here is my list of queued up projects / mods:
  • Upfitter switches OH console
  • Third brake light camera
  • Install new tailgate with steps
  • New rear door sill plates with Ford Performance logos to match front door sill plates
  • Spray tool box drawers with rubberized coating
  • Try to find / install a retractable antenna
Discussion starter · #183 ·
Discussion starter · #184 ·
Updates (threads elsewhere) -
  • Swapped in a preowned tailgate with steps
  • Added a McGard tailgate hinge lock
  • Replaced waterlogged passenger headlight assembly
Discussion starter · #185 ·
Here’s what I am waiting on or have on hand:
Waiting for:
New wiring harness for tailgate
New harness splice kit for above
Driver side headlight assembly
Tailgate to be repainted
On Hand:
New tailgate lock mechanism
New TG emblems
New TG stripe decal
New TG 3D letters
Old TG camera, light, rods and locks
Discussion starter · #187 ·
Started to install the Upfitter OH console and wiring. Was also wanting to replace my driver side headlight assembly but the wrong side was sent to me.
Here is a picture of the Upfitter parts ready to go in.
I’m taking a Texas football is on TV break them will finish the install. I won’t be able to connect the relay box under the hood today - I need a step drill / tap to install the mounting plate for the relay box. But I hope to have the console with switches installed and lights working.
Discussion starter · #188 ·
Upfitter installed except I broke the little pin I need to add to the BCM connector. Just went to AutoZone and grabbed a little box of assorted pins…
Also needed a couple of copper lugs to splice the relay box power cable to connect to the mega fuse box.
Nothing was easy today. I’m tired.
Discussion starter · #189 ·
Bonus good news - the OH Upfitter switches are illuminated!
Discussion starter · #191 ·
I haven’t thought that far ahead yet! :ROFLMAO:
I do have on my “project list” to add a semi automatic electric retractable radio antenna. Old school stuff.
What would you use the switches for?
Discussion starter · #192 ·
Added the 200A mega fuse to the relay box power cable. Had to chop the cable and add the lugs and mount the fuse box to the battery box. I did not connect to the positive post yet as I waiting now for a new lead for the connection to the passenger footwell fuse box.
Discussion starter · #194 ·
I have this on order already! They didn’t have any at the auto parts store so I had to order some. Didn’t want to wait so I used old fashioned electrical tape until it arrives. Looks similar to what you recommended.
Discussion starter · #195 ·
Supplies are arriving…
Wiring harness tape and a battery lug crimper tool (hammer style).
Gotta rework the crimps and tape later.
Discussion starter · #196 ·
Quick follow up on the wrong headlight assembly being sent to me. I called Fairway Ford Parts, and after explaining that I had requested a driver side assembly, but failed to cross check the online cart to see another passenger side assembly was in it, I needed their help. After briefly reviewing my order history, they came back and said a Return Label was being sent to my email, a new driver side assembly will be sent to me this week and as soon as the passenger side return is in their possession, I will be getting a $21 refund for the difference in price.
This is great customer service and one of the reasons I stick to buying from Fairway Ford online.
Discussion starter · #199 ·
And just like that, I’m back in the grill removal so I can install a headlight assembly business!
Discussion starter · #200 ·
I completed the final pigtail wire going to the BCM spot #23 and added the under-hood relay box mount - drilled in with a drill-tap and did not drill into anything behind it or through the exterior of the fender (thank you @GearHead_1). Now - I need to find something to add to the 6 new OH switches...
