201 - 217 of 217 Posts
Discussion starter · #201 ·
SVE Q-252 2017 and Later F-Series Super Duty Upfitter Switches PDF.
Adding here for future reference.
Since I used the Super Duty Upfitter Relay box and harness (also from the Raptor, I think?) I am posting this nice little PDF which has details on the relay box's wiring, wire colors, Circuits, fuse numbers and ratings as well as wiring diagrams. Also shows you how to configure Upfitter switches 5 and 6 to be hot at all times.
Note - any Upfitter discussions on Super Duty pass-through wires located around the passenger foot / fuse box area are not covered in this PDF. Those wires are not connected to the Upfitter Relay harness. They are, as named, just short wires passing through the firewall. And, as I have read, they are incredibly short and impossible to reach to add wiring to. These pass-through wires are not found on F150's.
Discussion starter · #202 ·
Installed the driver side headlight assembly today. Last time I tried, I found after raking the grill off that I was sent the passenger side assembly (again). This time all was A-ok. I’m getting very, very adept at taking the grill off and swapping out headlight units.
We have plenty.
Used the feature once in first week of ownership on some trails to christen the purchase.
Worked really well, impressively consistent actually. Good for freeing Up your legs for bracing yourself while you dangle from the seatbelt 😆.
But I don’t think I’ve used it again since; granted I’ve also never attempted anything as gnarly since then either.
Discussion starter · #209 ·
Ha! I was thinking to use it on a steep, hilly roadway around here. Maybe a long hilly driveway. I may have to make a foray off road after all.
Discussion starter · #211 ·
FYI - attention racers and folks really worried about weight…
The H6 Motorcraft battery comes in at 47 lbs.
The H7 Walmart battery is about 52 lbs (maybe slightly more with the extra label added on top).
The next owner of your truck might be very confused if they ever look at the window sticker.
But after confusion wears off, they should be quite happy.
Discussion starter · #214 ·
Good point - I will print off a list of mods to tape onto the bottom of the window sticker copy I have!
Discussion starter · #215 ·
New rectangle, metal hitch cover, decorated with a really cool F150Ecoboost.net decal (slightly trimmed on the left side to fit the new hitch cover).
