Summary of my projects / mods.
1 reading
60K views 216 replies 25 participants last post by  Boatwaco
#1 · (Edited)
Since getting my truck in September and reengaging with this awesome Forum, I have steadily completed a few projects, mods and accessories on my F150.
Here is the list as of today. I’ll update over time.
Any questions ask away, except for cost. I’m in denial there.
My 2018 F150 Lariat projects:
X = completed
X Ford Wheel well liners
X Ford molded Mud flaps 4x
X Rear seat release latch
X 3D tailgate letters
X Console vault “safe”
X Autostart eliminator device
X Tuffy under seat lock box
X new combo locks for Tuffy box
X Cobra custom foam inserts for Tuffy box
X GG Bailey custom floor mats
X WeatherTech 6 window shade set
X Replaced hood latch due to false alarms
X Bedrug for bed and tailgate
X Ford soft roll up tonneau
X Ford horizontal bed cargo net
X Replaced OEM fog lights
X stubby antenna…
X a bit longer stubby antenna…
X a bit longer Raptor antenna
X new chrome OEM square exhaust tip
X painted black OEM square exhaust tip
X Red Ford Performance tow hooks
X E50 fire extinguisher
X Catstraps theft deterrent straps
X Skid plates front to fuel tank
X Headrest DVD player
X Sunroof sunshade
X RCI catalytic converter plates install
X Rear Bilstein 5100 shocks
X Tow hook rubber covers - reinstall
X Rear Hellwig sway bar
X Front Hellwig sway bar and new sway bar links
X Tailgate Alarm
X Relocated front plate to driver side bumper pad
X Black and red silicon cup holder inserts
X Ford Performance Door Sill Plates
X dv8dz9’s lower STX honeycomb front grill
X Drive mode switch - recalls last drive mode
X PRNDM light strip on center console
X Red tape inside mirror hinge - visual queue they are folded in
X Front grill emblem camera and side mirrors cameras installed - CameraSource kit
X RAS 3611-Y active suspension
X New black lug nuts and locking lug nuts
X Custom (home made) black center wheel caps
X Undercover swingcase bedside tool boxes
X Boosted GreyGoose harness to allow mirror spot lamps on anytime, any speed.
X Kicker speakers in all four doors. Straight swap out if the OEM B&O speakers.
X Relocated the DM button from lower left to upper right panel on console shift handle
X Front Bilstein 5100s at lowest setting.
X New IWE’s
X Switched out the 12V plug with the Ford cigarette lighter assembly
X Replaced the bed side rails
X swapped in a preowned tailgate with steps
X tailgate hinge lock - McGard via Ford
X replaced passenger headlight assembly due to it collecting a lot of water (leaking)
x replaced driver side headlight assembly due to leaks
X Added a tailgate with step
X Added an Upfitter OH console and relay box.
X Added Hill Descent Control
X Added Raptor style grill lights
X QuikSnap window sunshades
Equipment bought:
X Pro Eagle Kratos and 6-ton jacks
X Pressure Washer
X Breaker bar; adjustable length
X Riobi 1/2" 18V Impact and a ton of impact sockets and adapters
X ATPEAM Macpherson Strut Spring Compressor Kit Spring compressor reviews and stories
X Ryobi 18V angle grinder / cutoff tool
X HP Tuners MPVI3
X Metabo 6- Gallons Portable 200 Psi Pancake Air Compressor
Still to do:
Fumoto valve
Rear view camera mounted on 3rd brake light
Ambient light kit (interior)
Ambient lights on door sills (modify kit to work with Ford Performance sills)
Light kit for PNRMD by shifter
Install a semi-auto retractable FM antenna
Install Ford Tow mirrors
#33 ·
Everything stashed here is pretty much some type of project - gotta start working on these!
Most are for the truck, some for the old car, some for the house, some for upcoming Fall Harvest season - this year I’ll try to not only have a photo op pumpkin patch bit a faux corn maze for the little toddlers.
Oh! There is also a box of swag for the forum 10th anniversary celebration. More to come soon on that event!
#35 ·
Thanks @stereotype one ! That was a fun lunch meet up! We gotta get more of our a austin-area trucks and drivers together, more often.
And you’ve done a great job with your truck too. From the rodent deterrent under hood to the rear gnome house size exhaust tip I really like your truck!
#41 ·
Today was a simple install…
X Retractable stake pocket tie downs.
note - these are Bullring brand. Bullring makes a front pocket offset version, for trucks like mine (typically 6.5’ and 8’ beds) where the front pocket is not centered under the rail trim cover. That part number from Bullring is Model #4035
The rear units are Ford branded by Bullring. Part number VFL3Z-99000A64-D for a pair.
#42 ·
X Also put my tow hook rubber covers back on. Had to drop the front bumper to do this little task. Found previous owner had already cut the shutter cable?
Before - no rubber covers
After close up
After full bumper view
After close up other side
#49 ·
#56 ·
I’ve always liked my current ‘18 F150’s predictable, moderate understeer when turning in aggressively. Best handling F150 I’ve had was a ‘94 Lightning. That was a truck body on a sports car. Very enjoyable to drive hard.
Today my ‘18 is approaching the overall handling feel I’m looking for. A lot to ask from a 157” truck, but I’m liking what it’s got so far!
#57 ·
If you want even more turn in, you can go aftermarket sway up front.
Or for sure get some front end alignment suggestions from GearHead_1
I realize the F150 doesn't have the range of adjustment a sports car does, but it might have enough to accentuate what you are looking for.
I like the steering to feel less assisted. Weighted if you will?
I think you have to sacrifice some self-centering to gain the weighting, but it's doable.
#61 ·
Today I installed a Front Hellwig sway bar and a pair of new Ford sway bar end links. I never want to do this again. Had to R&R the really heavy RCI skid plate with cat theft deterrent wings to get to the sway bar. That’s really awkward and heavy to R&R.
#63 ·
I really like the handling now that I have the front and rear Hellwigs, and rear Bilstein 5100's on. Very firmly "planted". The stance feels "wider: - more secure - and very predictable steering feel tossing it into a corner. Granted, I do feel more of the smallish ripples and bumps, but not anything of concern.
#69 ·
I was thinking about those big yellow bump stops… not Ark’s truck?
Nope - his are brown
#71 ·
That's some awesome photograpy !
Also, notice my axle housing isn't rusty !
