. DA5T-14D544-BD The latest SYNC® update includes all of the improvements from previous updates, plus additional benefits, such as: Information display on the homescreen for HD, Sirius (if equipped), and FM radio sources Simplified graphics and improved usability Enhanced voice destination entry for SD Card Navigation (if equipped) Improved Navigation vehicle positioning (if equipped) Rear view camera guidelines set to ON by default (if equipped) Updated SYNC/device compatibility information The installation of this update will take up to 30 minutes to complete. Be sure to keep your engine running, not in accessory mode, throughout the entire installation process. Turning off your vehicle during the update installation will disrupt the process. Although your vehicle must be in park when you begin the installation process, you may drive your vehicle while the update is downloading to your SYNC system. If your vehicle is equipped with the Intelligent Access with Push Button Start feature, you will need to temporarily disable the Automatic Engine Idle Shutdown (AEIS) component before beginning the installation in order to prevent your vehicle from timing out and shutting off the engine before the software update is complete. To disable this feature, use your steering wheel controls to navigate to the Settings menu on your left-hand Instrument Cluster LCD display. From there, select Vehicle >Auto Engine Off >Off. (If you do not see this setting, there is no need to make any changes before starting the update.) Alternatively, after initiating the installation, you may drive the vehicle during the update process to avoid the engine shutting off. The AEIS will automatically reset to "On" the next time you start your vehicle. Please note: During the update installation, SYNC will temporarily appear to not recognize your mobile phone or media device. This is normal. When your system has been successfully updated, SYNC will display a notification saying, "Installation complete." __________________
