141 - 160 of 162 Posts
I may do it at some point, this truck rode better stock than my 2013 did so I'm happy with it. The 2013 had FX4 suspension and 20" wheels, the next truck is just "normal" suspension and 18" wheels so that helps quite a bit.
C’mon you have to do the fronts! Personally, it would drive insane if I did not have the same on all four corners. Pony up the cash and look back later. Sell one of those softball trophies! Glad you like the feel of the rears.
How many of you that have installed Bilsteins in the rear have re-torqued the bolts/nuts after driving for a few hundred miles? I didn't use threadlocker since I'm lazy and didn't go to the store and buy any. lol
I have not. 2000 miles on hers. Should I?
Not sure, I heard on one of the install videos that it is a good idea too. but the nuts are lock nuts (from what I remember) so you shouldn't have to.
They were my Fox shocks, but yes I did re-check them after about 2000 miles.
They were just as tight as when I installed. I wouldn't lose any sleep over it.
So I washed my truck the other day and the hose from the self wash caught the top of my antenna and unraveled the wire around it. I had initially cut 6" off the antenna so it wouldn't hit my garage every time I pulled in. Ended up just unraveling the whole wire and cut it with tin snips at the base and expected radio signal to be diminished...but it didn't get any worse.
How could it catch the wire if the ball is on top?
Also your imgur links never work for me, not even once. It says zoinks failure
Because I cut my antenna down the day I brought my truck home so it wouldn't scrape on the garage ceiling everytime I pull in or out of the garage...aka, the ball and 8" of my antenna are in the trash.
And not sure why they don't show up, are you on a computer or Tapatalk? It shows up fine for me on my heavily monitored work network.
You can pop the ball off with a back of a hammer or something similar and JB weld it on to other end and paint. This is what I did on the truck and all vehicles. It looks real clean.
I plan on wrapping aluminum foil around the top to get better reception like my parents did on the TV antennas we had growing up.
(*sarcasm*)
Impressed yet again with the mileage of this truck. Round trip to St. Louis and back this past labor day weekend along with a bit of driving around Downtown. All while driving between 75 and 85 mph on the interstate.
Ugh fricking Tapatalk.. Wish I could see pictures
Tapatalk issue....... Typical finger-pointing currently.
Which means NOBODY is working on it. Lol
Yeah it's irritating.
It's funny because when I first started using tap talk I could not stand it, now I can't stand using the regular web page.
