21 - 40 of 77 Posts
Makes a big difference every time I do it. Even tuned.
when i worked at a dealer. We did this a lot on multiple vehicles. They called it a throttle adaptation. It was just a way of resetting its memory on 0-100 position. It definitely works.
Forgot to do this after putting 93 p/t back on after running 4 tanks with 93per tune (highway) loved it! Then put back to stock for service then back to 93 p/t, after about 300 miles it seemed like it stall then take off at most speeds with throttle input. I thought the PCM was trying to 'learn' the new tune and then "du" I forgot all about the throttle reset and now it's back to normal (fast:):)). LOL. Gas mileage is better also!
Thanks for putting this up. Makes a difference on my 2012.
Anyone have any luck with a push button start? Im giving it a shot right after work. Im in a 2017 Navigator. Im guessing push the button to power up, then go theu the gas pedal steps after the chimes stop. We'll see how it goes.
I did it on my 2017 navigator after work yesterday and i really noticed a difference ????
Is that a question or a statement? LOL
I'll give it a try on my '16 and see if response improves, although I never really realized if it was lagging or had a "dead spot".
My truck has been rock solid. Decided to try this just because, feels exactly the same. But like you I never noticed lagging or dead spots.
Is it the same for the push button start system ? Just push instead of turning the key ?
Sent from my SM-G935W8 using Tapatalk
Take a pill
No pill needed. Thank you though.
Why would you not check the thread that you already posted on first before making a new post??
Long day. Cheers to the ribbing.
AND again I did the throttle reset and it worked !
I do a fair bit of city highway on off the gas and the truck felt sluggish. Not now.
Wow. I just stumbled on this thread again which reminded me that Ford changed my oil and did the brake booster fix since I last calibrated. That probably kicked the pedal calibration back to stock.
My wife thinks my driving sucks because I holeshot away from stop signs. She doesn't understand the dead spot issue (which had NOTHING to do with the turbos coming late to the party).
I just went out and recalibrated my pedal and it made a huge difference. Think my wife will believe me?
Sent from my SAMSUNG-SM-N900A using Tapatalk
21 - 40 of 77 Posts
