21 - 40 of 42 Posts
I drive somewhat aggressively and rotate only every 20k miles or so. My front to back wear rate is not far apart to rotate any more often.
Currently have 36k on stock Goodyear HTs and at 6/32nd all around; measured just yesterday with tread gauge.
*jaw dropped*
I would never even dream of that
I have just over 40K on my original Pirelli Scorpion 20's. Never rotated, pretty even wear too, great tire in wet or dry. Looking to get a new set before winter. Would like to maybe go with a taller tire like a 735-60-20. Pirelli doesn't make that size though.
I work for a tire shop in Denver and usually see 40k-50k on most f150s. Curvy roads definitely do there toll though on tires. I would maybe try to step up to a 10 ply rated tire. Might hold up a little better. Had a customer just yesterday come in with his 2012 Screw that got just over 60k on his 20” hankooks.
By the way for you staggered rear wheel drivers. I usually tell people that you will go through about 2 pairs of rear tires for every front. Plus all mileage warranties get cut in half on these vehicles because you can not rotate them. Just some food for thought.
Never seen an f150 with staggered sizes.
He was referring to someone who posted previously about how RWD cars you would expect the rears to wear out 2X's as fast as the front...or something like that. Not referring to F150's (per se)
I concur on the 60k on Hankooks. Good tire with real good wet traction.
OP you said you have short commute and drive aggressively. Try for the next 10k miles driving like your grandma is in the front seat and see if wear slows.
Discussion Starter · #28 ·
What, so no more of this???
I have 69,950 miles on my OEM Wranglers and still have plenty of tread left (9/32" as of a couple weeks ago when I last checked) - although I have the 2" level kit ready to install and will be swapping the tires out real soon. I keep a constant 40psi in the tires and rotate at every oil change.
I'm in the same boat. I have 53K on the oe Pirelli's it's time. I want a larger size also and have not made a decisions yet.
I'm about to take my stock Wranglers off next week to swap to the Cooper AT3's. All highway driving and I have 71,000 miles on the stock tires. Keep them at 40psi and rotated at every oil change. Yesterday while installing my Bilstein 5100's up front, the tread depth was 6/32" and nice and even. I was definitely impressed with the mileage I got out of them!
You must not drive anywhere near snow?
Weird... my stock Wranglers (junk) did not even last to 50k?
Do you think their is a problem with my Boost?
Maybe because I have 3:73 gear set?....or maybe it has something to do with my right foot?
And....what about my gas mileage-lol
I have 65,000kms on the Hankook atm's. I rotated them once. I they are about the same wear front and back, about 35-40% left. I have smoked them many times. I drive very aggressively. I use them in the winter every year, which means they get spun up even more. I'll probably replace them next winter.
Nope, but I have no idea what that would do with it, unless you think that with snow you'll have additional tire spinning to wear them down faster.
I live south of I-10. No snow here!
No its the lack of traction...
Sent from my SM-G870W using Tapatalk
Discussion Starter · #38 ·
I got 19k, tires were 2,2,3,3, so even wear.
Went to the Falken Wildpeak A/T3W models.
I always get the prorated mileage, so it's not too painful.
They look good, they do spin a little more on a quick "pull out into traffic" than the Coopers, but the wet traction seems to be better though.
I'm shopping for tires and gonna bring back this thread before it dies. Currently running Cooper At/3 275/70 18's on stock rims, and put Bilstein 5100's on when I got them and set to 1.2" lift. Bought them 3 years ago from tomorrow and have 34k miles on them.
There's probably about 7/32's around on all, and have worn evenly. But I live at 6500' elevation and theres a bit of snow potential for about 4-5 months here, sometimes more. Thus, I'm getting ready to get new tires, though my current ones aren't doing too bad this winter, but considering winter, it's time.
Elsewhere I think I'd get through the winter with them, but at 34k I'm gonna bite the bullet soon and get a new setup on new Methods, probably a bit bigger.
Conclusion: Cooper AT/3 LT 275/70 18 - Replacing at 34-35k though I drive in the mountains, with a bit of weight in the truck at all times. Lots of hills and turns here on bumpy worn-down roads, and I drive somewhere in the 'kinda fast' speed range. So I think considering everyone else, I guess I'm happy with them.
Discussion Starter · #40 ·
I can say that the dealer has told me the Wild Peaks are wearing as they should at this point. Much better than the Michelins and Coopers were. They get a little squirrely under gas in turns, but seem to have good lateral grip.
21 - 40 of 42 Posts
