How often are you guys rotating your tires? I'm sure everyone is different as tires wear different, but I have the stock Pirelli tires on the 20s
You don't have to retrain your tire pressure monitors sensors after a tire rotationOk. Well as long it doesn't make rotating tires any different then no harm no foul. Ford FTW Sent from my iPod touch using Tapatalk
Found out the sensors are trained to their position. Rotating won't hurt them but your fronts that are now your rears will tell the computer they are fronts and when one of your rears goes low the light will come on but it will tell you a front is a rear or a rear is a front and you will actually have to use a tire pressure gauge or, heaven forbid, LOOK at your tires to see which one is going flat! Just be careful you don't change the wrong tire on the side of the road only to find out your mistake or worse yet, think you have another flat!You don't have to retrain your tire pressure monitors sensors after a tire rotation
Exactly correct. In fact, I put a set of snow tires mounted on separate rims WITHOUT the TPMS. If I drive for more than 25 miles, the warning will come on (because I have no TPMS). BUT, when I return home, the tires are stored in my garage (about 10 feet from where I park) and the sensor light goes out ... everything is back to normal.You don't have to retrain your tire pressure monitors sensors after a tire rotation
I never thought about the "time condition" but you could be absolutely correct. Most of my driving is "In-Town" and it's not a big town, so the time condition would never be hit either. The only time was when I was going for a drive "out-of-town" and that is all highway speed ... so the time would match the distance I travelled.I too thought it was due to mileage when the light came on but it's not.
It's actually based on time driven.
I also have no tpms sensors in my winter wheels and for the first few days the light never came on.
I was only driving 20km(exactly) back and forth to work in good traffic conditions, approx 20mins.
Then one morning traffic sucked and it took me 25-30 mins to get to work and, bing my tpms light came on.
The system must monitor every 25mins or so(sounds like a nice round number) just to set position and check for radio signal.
I'm sure if the sensors where actually there and a tire went low it would be noted on the dash much quicker.
Vehicles differ by manufacture in the way they monitor position.
Some need to be set and do not consistantly check for sensor position or radio signal after so many miles or mins.
Others due check and set at different times or distance driven depending on manufacture.
Just don't be lazy and check your tire pressure regularly.Ford's TPMS system meets the bare minimum regulation for tire pressure low notification. Even though calibration is performed so the PCM can identify each individual wheel, it does not provide this information to the driver. GM's on the other hand will provide the actual pressure of any tire, and if a TPMS event occurs, which tire location is affected (LF, RF, LR, RR). Ford can and should do better in this area.
I'm rotating around every 10k miles.
I find these things to be a piece of nanny state annoyance. Waste of money. They fail to often. Yup.Just don't be lazy and check your tire pressure regularly.
Yes just rotated mine. Actually took the back right made it the back left and front right became front left, front left became right rear. Only did this due to the tread depth. Didn't hurt my alignment none.
And figured id have to train the sensors after all the crap I've heard about people putting new wheels etc on. But nope.
Manual states only for vehicles with different front and rear psi requirements.
