Do you mind posting up some pics to show what you trimmed?The rims have to have an offset. If you go to BDS Suspension's webpage n go to the year truck you have it will tell you how much backspacing is needed/recommended. Mine still rubbed a little bit when backing up n turning. But with a little trim of the front valance....problem solved.
Some MT's have pretty large side lugs that will rub the CAs.35's will fit, but you can't go 12.50 wide without offset wheels.
