I am considering two different trailers and would like some feedback. My vehicle:
2017 Ford F150 XLT 4WD
Supercrew Cab, 145 inch wheel base
3.5L V-6 Ecoboost
Max Tow Package
3:55 Axles
GVWR 7000 lbs.
CGWR 16,900 lbs.
Front GAWR 3450 lbs.
Rear GAWR 3800 lbs.
Conventional towing capacity with weight distributing hitch 11,500 lbs. Fifth-wheel towing capacity is 10,200 lbs.
The two trailers I’m considering:
Travel trailer: Keystone Outback 324CG. UVW 7974 lbs., GVWR 10,500 lbs., carrying capacity 2526 lbs., hitch weight 870 lbs.
Fifth wheel trailer: Keystone Cougar 27SGS. UVW 8046 lbs., GVWR 10,290 lbs., carrying capacity 2244 lbs., hitch weight 1495 lbs.
I also plan on adding some type of suspension upgrade (although it will not legally raise my carrying capacity) such as the Roadmaster Active Suspension kit. Which trailer would tow better with my truck? We plan on using if full time, only driving short distances and staying for a few days at a time. Transmission service and oil change intervals will increase.
3.5L V-6 Ecoboost
Max Tow Package
3:55 Axles
GVWR 7000 lbs.
CGWR 16,900 lbs.
Rear GAWR 3800 lbs.
