I keep getting this message while pulling my brand new 16' tandem. It goes from the disconnected message to the brake gain message. Then back to the disconnected message.
The lights keep working despite what message is on the dash.
I found that there was a TSB for something similar but they intended that for people having this problem without a trailer connected.
My 4 flat connection has worked flawlessly for years.
I think it must have something to do with the wiring on the trailer itself. Most likely the brake circuit. If a break away battery is bad, what are those symptoms? How do I check?
Not familiar with trailer brakes. Any help is appreciated.
Trailer has 150 miles on it. It did not do this when I first towed it home but has done it the last two times I've towed it.
