1 - 19 of 19 Posts
Im not sure why but my truck feels really sluggish lately. Mainly when I floor it it just doesnt feel near as fast as it was. It actually seems faster at about half throttle. The motor screams but it just doesnt seem to be going anywhere. Any thoughts or suggestions would be greatly appreciated.
I replaced the plugs not long ago but im going to replace them again with some that come pre gapped at .30 if I can find some. How would I know if I have a bad coil pack?
Reactions: outlaw25
Is your air filter clean???
i would think that if you changed plugs you would see some indication by the plugs if it were a coil issue or injector problem, also i would hope the ECM would pick it up and give you a light and code.
i would look closer for an air leak somewhere or a turbo problem that cant be seen by the ECM.
it could be any number of things
Some times the stock BOVs will go out if your running higher boost, or a small leak in IC piping. Do a boost leak test, boost leak tester will be your best friend when you own turbo vehicles.
Discussion Starter #10
Yea air filter is brand new afe stage 2...thanks for the suggestions I will do a boost leak test
Also iv'e made a recent discovery
Its probably been posted somewhere on this forum already but.....
2011-2012 has BOVs located on each turbo
2013+ has electronic single BOV on the LICP
i can see the Elec BOV giving up quick
I can't. It's an electric solenoid.
Why would it be any weaker than any other setup?
HUH ! i have no idea what your talking about !
are you sayin lower intercooler pipe ?
Sorry guys, i did mean Lower Intercooler Pipe
CAC = charge air cooler, lower intercooler pipe is part of the charge air cooler
i don't think the intake would make a difference unless the filters got clogged some how
Scap, i can see an electronic Blow Off Valve going bad since its electric
but im sure the ECU would pick up on this pretty quick
plus its only designed to hold stock boost
Just trying to spread some knowledge :)
might not always be the best............
The bov is mounted to the driver's side tank of the cac.
Mine holds 22psi...
Mine holds 22psi...
Sweet!!
ok so the pipe that Full-race shows on their site is not stock location
you know ecoboost f150 spec sheet would be sweet
Scap, are you holding 22lbs at WOT all the way to redline?
Sweet!!
No, it spikes, then tapers some.
1 - 19 of 19 Posts
