1 - 11 of 11 Posts
I have a 2012 ecoboost and am having problems with a studder on acceleration. I have changed the spark plugs and I have put a new turbo on and it still studders. It only does it when the truck is really warm that I have noticed. On colder mornings it doesn't do it. I'm trying to figure out what it could be.
2016 Ford F-150 XLT 2.7L
Well, I’ll give it my best go.
Studder can be caused by condensation in the intercooler.
But before I go any further, Is your truck 100% stock? No catch cans? Intake etc?
It also could be the boots on your coil packs, or a coil pack itself.
How often do you change your oil?
Discussion Starter · #3 ·
Yes my truck is 100% stock. I have had nothing done to it. My oil gets changed every 3k at the dealership. I didn't change my coils or anything when I changed my spark plugs.
Should I have replaced them when I did my plugs?
Ok great. Mmm, usually people don’t. I never do. But if you’re having stuttering issues you could replace them with some OEM ones (arguably the best) and see if that makes a difference. If not, I’d look into the condensation in the intercooler problem.
Reactions: stereotype one
Was the old turbo actually bad or ?
Definitely leaning toward condensation.
And how do I fix that problem?
You can drill a weephole. Youtube is your friend or on here somewhere.
I had the issue once when I got my pickup. WOT runs until the speed limiter shuts it down fixed mine. You will get a wrench light. Pull over, shut engine off, restart, do it again until no more wrench light. I am stock except for suspension and I haven't had issues since.
You should be sure your rig is in good shape with oil and coolant topped off first.
1 - 11 of 11 Posts
