3.5L GTDI - INTERMITTENT STUMBLE/MISFIRE ON ACCELERATIONFROM HIGHWAY CRUISE IN HUMID OR DAMP CONDITIONS
TSB 14-0017 link to it below
https://ford.oemdtc.com/TSB/14-0017.pdf
"Reprogram the PCM to the latest calibration level using IDS release 88.03 or higher"
Who has had this issue 2011-2014 and have actually let the dealer reprogram their PCM, what was your outcome after the reprogram? Did you continue to have issues with the CAC collection moisture? (please if you have drilled the weep hole this doesn't apply, I need actual information about if the reprogram worked or not and what it did to your truck *lack of power? *loss of MPG? *longer turbo spooling? etc?) FYI because some seem to have missed the point of this I UNDERSTAND THE ACTUAL AND PROBABLY ONLY FIX IS TO DRILL A WEEP HOLE OR REPLACE THE CAC, BUT I AM NOT ASKING FOR THAT INFORMATION ON THIS POST, I AM ASKING FOR FOLLOW UPS FROM THOSE WHO DID NOT DO THOSE THINGS AND DID THE TSB ONLY
My question is coming from the fact that no one at ford can explain to me how the reprogram will solve the issue, I have contacted Ford voicing my concerns about how it seems all these TSBs are just chasing the tails of the previous one. Example in this link where the release of the 2012 TSB to fix the issue and now the 2014 TSB basically undoing everything the previous one said was the permanent fix https://static.nhtsa.gov/odi/inv/2013/INRD-PE13018-58124P.PDF
