HI Folks....so I've having some issues wit my turbo..i think...im driving a 2016 3.5 eco 170k ...lately I've been starting to hear my tubro sqweel on a cold start ..but it stops once the truck kinda warms
up...but then I go to drive it..and there it is again...so I've been thinking my turbo is on the way out...the sound is coming from driver side...so ive been reading articles the last couple days on here about similar problems but yesterday a discussion on here opened a new can of warms...telling me it could also to be the exhaust manifold....soo..my question is ..how do I know if it my turbo or my manifold..? Yes..I could get ford to diagnose it but I wanna avoid tht...as the truck getting older and I wanna start knowing it...
From your description and not taking the previous thread/post that you had read into consideration, an exhaust manifold leak is what came to my mind. A mirror and a good light, check the mating surfaces between the head and the manifold to see if you can see exhaust stains blowing out of these areas. Check to see if it has popped a manifold stud as this is also a somewhat common problem.
Not to make light of the situation but yes, no, maybe, it depends upon if there is and where the leak might be and the tools you have and your ability to maneuver around under the hood to see things. Obviously not having the fender liner in the truck makes it easier to look around but I can’t tell you that this is a necessity.
i have had a leak on the turbo to manifold flange on one side, and a manifold to head on the other. both got better when it warmed up. soapy water on a cold motor will help you identify it
Same issue since 45k. Best friend has same issue, same year model.
Warped manifold. If is sound like air blowing over a blade of grass, like vibrating chirp, thats it. His broke the bolts off. Buy the after market manifolds, if not you'll be back in 40-50k doing the same thing again. Good Luck.
Here's a link to the sound clip...this was a cold start...idle...then several brake stands...
Sounds similar to my exhaust leak, it gets better after about 45 seconds but never goes away. It is usually the rear stud that is broken from what I've read. Remember, when you dig in to it you'll want to replace the connectors for coolant flow on the head and on the turbo - they will start leaking.
