Upgrade Radiator or CAC for towing?
46K views 49 replies 19 participants last post by  Boosted2012
I've towed 10k easily several times through Vegas and SOCAL temperatures (and through the passes), never once had an issue with heat. I've also never locked out a gear. The CAC is probably the most important upgrade you can do if towing often and in high heat locations. Should also consider a thermostat change as well.
Since you bought it used, you should check to make sure you don't have any problems with the cooling system. Make sure it's full and is burped adequately. With those miles, may not be a bad idea to drain and flush system. Maybe you'll find some buildup or other issue when you do it.
Take a look at the thread in my sig for more info on CAC.
