1 - 16 of 16 Posts
has anyone experienced upper noise by the bushings like creeking,2014 150 ecoboost platinum,65,000 miles with front level bilstein shocks.i sprayed triflow all over bushings and i think it cured it.are they shot or what.
Had same thing in my old 2013 with Bilsteins, I just sprayed it as well and it went away
Mine creeked something fierce. Tried lubing the snot out of it to no help. Ended up breaking out the pressure washer and having at the underside and suspension of truck. Completely got rid of the creeking that could be heard from 2 blocks away when driving.
Super Modistrator
You spraying the upper mount or the shaft’s entry point into the tube? If you’re spraying the upper mount your problem isn’t the shock and chances are it’s either dirty or rusty. Now if you’re spraying the shaft where it goes into the seal and the noise changes you’ve got a shock problem.
My case I believe was exactly as you stated, dirty. HELLA dirty as the truck was an oil field/mud road truck in her past life. Rode hard and put away wet kinda truck.
noise isnt by the shocks its the upper control arm bushings.i think noise is gone since i sprayed them.wasnt sure if bushings need to be changed or just alittle lube.
I've had to lube mine once and it was definitely the aftermarket upper control arm bushings. They squeaked like a 20 year old Dodge. Lol
Shot a little grease into the zerts and magically the truck got quite after a few trips down the ¼ mile bumpy road-driveway.
Super Modistrator
I’ve never heard a grease fitting called a zert before. Is that real or a typo? Something new everyday.
Super Modistrator
HA! Looked it up, tons of reference to a zert. Maybe it’s a regional thing.
Can’t trust the internet but I did find this. Zerk was an abbreviated version of his name. Thanks Snake, you at least got the gray matter turning today.
"Oskar Zerkowitz emigrated to the United States and changed his name to "Oscar Ulysses Zerk". He was also known as "Oscar V. Zerk". He became a world-famous inventor and one of his most prominent creations was a grease fitting known as "the zerk". This was a lubrication system which became the basis for those used on nearly every car, truck, plane, and other mechanized vehicle. At the time of his death in 1968, it was estimated that 20 billion of these fittings had been manufactured."
Super Modistrator
I read that too but I’m giving it to Snake. There are enough references out there to Zert out there that I think it’s gotta be a regional thing. I’ve just never heard it that way.
Yeah just thought it was a interesting read. After all the years of actually using something and knowing the history is pretty cool.
Lol
Don't EVER give me the benefit of the doubt when it comes to spelling or pronunciation.
I catch grief even from other southerners.
Some folks ask me to say certain words or phrases repeatedly just so they can hear it again and laugh.
Been that way all my life. Lol
OK, it's zerk.
Never too old to learn.
You're full of grace GearHead, and I appreciate it. But it looks like I'm officially ignorant according to TractorsByNet.
Super Modistrator
Yeah, and who is that person? Besides we’re not talking about tractor zerks we’re talking about truck zerts.
1 - 16 of 16 Posts
