21 - 23 of 23 Posts
I don't understand why so many are hung up on the 'no drill' requirement when you can purchase replacement pieces (intake pipe and airbox top) for $100. I wish someone would do an efficiency test (drill vs. no drill) to see what the difference is in what is captured.
Supporting Vendor
Discussion Starter · #22 ·
Drilling requires more work, and makes the install harder than a Direct Plug and Play. Yes the parts may only be $100, but to most that is $100 they can spend elsewhere if ever needed. Why replace them if there is a solution that does not require you modify them to begin with.
21 - 23 of 23 Posts
