1 - 6 of 6 Posts
I installed a Mishimoto intercooler and AFE charge pipes. Took it for a test drive. Gauge is showing zero boost. No cel. No codes in forscan. The electronic blow off valve seemed a little loose, but the o ring was intact. Where should I start looking. Any thoughts?
There will be a VERY definitive difference if your truck is or isn't going into boost. They are an absolute DOG without the turbos working correctly.
Since you installed a new component yourself, retrace all of your steps and eliminate "installation error" by making sure all leads, sensors, vacuum lines, and everything have be reinstalled correctly. ;)
^^^ what he said. Sounds like something is not connected on the tubing or connectors. You could also have some vac lines in the wrong location or switched.
1 - 6 of 6 Posts
About this Discussion
5 Participants
Blown F-150
F150 Ecoboost Forum
Full Forum Listing
