Valve cover keeps burning..
615 Views 12 Replies 11 Participants Last post by  Daniel23m119
6
I Have a 2013 f150 3.5 ecoboost. Valve cover keeps burning on passenger side. What is causing this? Cover looks fine from inside so it can’t be the valves.. I’m just confused. I replaced the burnt valve cover with a brand new one and same burn. Same spot. Weird. The water coolant line that runs beside it gets really hot but I don’t think it’s causing this burn.. are coolant lines supposed to get hot to touch? Thank you
Motor vehicle Metal Automotive tire Auto part Nickel
Metal Gas Auto part Automotive tire Font
Motor vehicle Automotive tire Hood Automotive design Auto part
Automotive tire Plumbing fixture Grey Bumper Tints and shades
Automotive tire Hood Bumper Office supplies Tread
Tire Automotive tire Tread Wheel Fender
See less See more
  • Wow
Reactions: 1
1 - 13 of 13 Posts
It could be the coolant line that is causing the issue and yes they do get hot but there usually engine temp hot which could range from 190-215 degrees could be higher depending on load conditions to. If the valve cover isnt leaking i would put it back on and run the truck and get a temp gun to see what the temps are in that general area.
Reactions: 1
Coolant lines should not get hot enough to melt plastic.
You could wrap that coolant line with some heat tape, exhaust wrap type stuff.
Sent from my SM-S901U using Tapatalk
Reactions: 5
Exhaust manifold leak?
Reactions: 5
^^^ - if it was the coolant line we would have seen this happening a lot! Manifold leak is a good place to look.
Reactions: 4
Yeah, I gotta believe you've got an exhaust manifold gasket that has given it up.
Reactions: 5
I was also going to chime in the same before I scrolled down.
Reactions: 2
What's going on with that COP that it needs duct tape?? This looks like the wiring there could be arcing to the stud holding the cover on. Looks like several smalls burns to me. Is the wire insulated properly?
Not very knowledgeable in this as most of yall, but if the manifold was leaking wouldn't there be more than just that part of the valve cover melted? Like the piping around it? Just thought Id ask from the peanut gallery lol
And there should be a loud noise that you might be asking questions about. Or be concerned about.
Reactions: 1
If it were a pinhole or very localized exhaust leak it could point right at that spot. You would think that you could hear it though.
Wouldn't be hard to find out if that was the issue.
Reactions: 4
I would vote no way this is coolant related. This looks exhaust leak related to me. Did you figure it out?
Reactions: 2
Thanks everyone. It was an exhaust leak. Changed both sides exhaust manifolds and turbos plus coolant lines.. changed the burnt valve cover. She’s running really nice again! I had the exhaust manifold bolts on the wrong way the first time I changed it so it wasn’t grabbing onto the block as it should. All good now!
  • Helpful
Reactions: 5
1 - 13 of 13 Posts
