Sorry in advance for the long post...
Having problems and wanted to reach out and hopefully get some input from some of the knowledgeable members on here. Thought a separate thread might get more attention and be more helpful than sticking it into my build thread. Haven't put much time or significant miles (only about 3k miles in the last year) on the truck in quite a while and I'm ready to get back in the saddle and get everything sorted and perfect, I do have a few little developments for my build thread and will update it in a bit. I don't drive it as a daily anymore as I mainly use a work truck, every other weekend I'll use it for some errands or just take a stroll on the freeway to break off the cobwebs.
Current Setup:
2011 FX4 chassis
Full bolt-ons
Forged bottom end
Pocket port, fancy valves, springs, and retainers
Full Race GT/ 'OEM+' turbos with block off plates on the diverter valves
TurboSmart IWG-75 wastegate actuators, pretty sure they have 7# springs in them, preloaded to 4 turns I believe
Converted to single TurboSmart BOV on the Full Race charge pipe, reference line from throttle body spacer
Full Race PCV delete kit
Full race dual chamber catch can installed on firewall
Amosil Super Synthetic 0w-40 and Mobil1 filters
99% of the time I'm in manual shift mode with traction and advance trac controls turned off.
Symptoms:
-Top end sounds slightly off and feels like there's unclaimed power on the table
-Overall feels a little laggy at times down low. Sounds funny to complain because in wet-ish conditions it will spin heavy 34" load-E AT tires and kick sideways in 4th gear at 70mh
-Whirring/ turbulence noises like a jet plane, probably just intake noise and wastegate fluctuation noises.
-Lots of air from the BOV when decel or coasting above 2500 - 3k rpm's. Could be normal, could be wastegates not opening enough?
-Not hitting #/min that I'd hope to see. Trying to get as close as possible to the 60 #/min max of the GT turbos, but progress is halted due to the following issue
-Lots of valve train noise, I attribute it to the valves and stiffer springs
-Variable Cam Timing is not hitting its target inputs. See graph below of what @Boostking is commanding vs. what I'm datalogging. Seems to be mechanical rather than tune related
-Odd clacking noises from what I believe are the cam phasers. Only hear it for 1-2 seconds if I'm slowly rolling to a stop, or if I hold idle at around 1,000- 1,200 rpm's.
-Occasional clack at cold start for just a second, I generally prime the motor when its been sitting for a while
-Oil in exhaust. Smells fuel rich and like there's oil being burned
-Oil in hot side pipes and elbows from the compressor outlets
-Hot pipe fittings have popped off the compressor housings before. The clamps provided by Full Race seems to be too wide to leave some unclamped silicone while clamped on the correct side of the barb/ bead rolled type compressor outlet fitting. Temporarily installed a hose clamp on the passenger side and it hasn't had an issue yet
-Lots of signs of oil coming from the BOV. Everything in that vicinity gets some oil film on it
-Catch can not catching any oil. Bone dry since install with the new engine and setup
-I lose about 1/2 - 1 quart of oil between oil changes
Guesses:
I'm assuming the low #/min, VCT advance, turbo seals, and empty catch can are interconnected issues. Plenty of info out there showing increased crankcase pressure raising the oil pressure, which can push oil past the seals, and probably affect VCT functions. I bugged @RMB_Ryan a ways back and flushed the oil and started using Amsoil at his recommendation. No change in datalog results
Approaches:
-My first approach was checking to make sure all my wiring, grounds, vacuum, evap, etc. lines. All seem to be in place and routed correctly to my knowledge.
-Planning to pull apart and check seals on the wastegates and BOV, and pull plugs and coils and send a scope down
-Can I troubleshoot resistance of the phaser solenoids and/ or cam and crank sensors?
-Next step seems to be to add an external oil pressure sensor, and hopefully hook it into my Livewire TS+ device. I reached out to SCT asking if they recommend specific sensors that would work with the analog livewire inputs. They told me to dig around the PIDs, but from what I've read the Gen1 motors don't provide that info to the PCM.
-Been wondering if I should temporarily hook up cheap mechanical gauges to the catch can lines to monitor crankcase vacuum or pressure and drop through the can
Any suggestions on things to check or where to start? Videos or articles I could check out? The video link below seems to be the most relevant I've found, but I don't have IDS tools and assume the dealer wouldn't be too much help or cost effective. I'm very willing to post any more info you guys feel is relevant (vacuum routing, pictures, datalogs, etc.)
Current Setup:
2011 FX4 chassis
Full bolt-ons
Forged bottom end
Symptoms:
Guesses:
Approaches:
