Been a while since I’ve posted, mainly because everything has been going well….till today.
Only change has been that the truck now has 105K mi
I went to pass someone, pressed the gas and blew by him. When I let my foot off the gas I got the usual woosh of my BOV and then the truck started shaking. CEL began flashing. I began looking for a spot to pull over and after 30-40 sec the engine smoothed out and the CEL went away. Drove fine after that.
Got home and hooked up Forscan and I had misfire codes for cylinders 1 & 6. I cleared the codes and took the truck out for another ride.
Driving normally had no problems..as soon as I gave it enough gas to push the boost up..CEL flashing again…disappeared and smoothed out after 20-30 seconds. Hooked up Forscan again and this time says Cyl 1 misfire.
Friend of mine said to check the spark plugs for cracks? They only have about 40K miles on them, OEM ford plugs.
Just looking for anyone who may have had same/similar issues?
PS I am using aftermarket coil packs..I’ve heard they can be the cause of a lot of problems? I’ve ordered 6 new OEM coil packs.
