Was wondering if anyone had used it to clean thier MAF sensors .. it's designed for sensitive electronics and evaporate quickly just like MAF chargers from auto parts store but has a bunch of other uses too
But the CRC MAF sensor cleaner works on MAP sensors very well! I get the technicalities of naming but slip as often as everyone else. KMFun fact, there are no MAF sensors. All 3 sensors are pressure/temperature sensors
Yes it does work. Just letting the OP know.But the CRC MAF sensor cleaner works on MAP sensors very well! I get the technicalities of naming but slip as often as everyone else. KM
is the first sensor after the air box not a MAF… other MAP’sFun fact, there are no MAF sensors. All 3 sensors are pressure/temperature sensors
only the 2011’s. 2012 and on have a pressure sensor.is the first sensor after the air box not a MAF… other MAP’s
Didnt know that . They could still be cleaned I suppose thoughFun fact, there are no MAF sensors. All 3 sensors are pressure/temperature sensors
Thank you!Yes it does work. Just letting the OP know.
Ive used it in several of my vehicles works greatWas wondering if anyone had used it to clean thier MAF sensors .. it's designed for sensitive electronics and evaporate quickly just like MAF chargers from auto parts store but has a bunch of other uses too
