3141 - 3160 of 3179 Posts
I wanted to do full long travel one day so I was going to opt for the bigger fenders. I'm not a fan of making my f150 look like a raptor but man is it way cheaper to go that route. It just a pain trying to source fenders where guys don't want your first born in return.
The plan was to show you my newly plasti dipped skull caps but I may have an issue. So I have a question for those that have used Plasti dip before.
The problem is it feels really soft, almost like the slightest impact from a bug might take it off.
I bought a kit for rims and it came with a clear coat. Do I have to use the clear coat? The instructions on it indicate to use it if I want a glossy finish which I do not want. So I wasn't planning to use the clear coat.
Sent from my Pixel 3a XL using Tapatalk
It's rubber it's meant to be soft.
You can have plastic line x. It just does not adhere as well like steel. If in a high impact area, it could chip. But it is stronger than plastidip. If the object is small like you have, just ask a shop to do it once they do a larger job because they will have material left over and pay 10 bucks or whatever.
Thanks for the info guys. I went ahead and put them on today.
Look really good! I like how they turned out
I didn't do anything to her truck today.
Except admire it, as I headed out to my essential job this morning
Changed oil, 6 qts of 5w-30 Mobil 1, a motorcraft filter; and cleaned all the intake sensors .
Super Modistrator
Now that you’re warmed up... maybe you could stop by. ;) I’ve got an Edge that I’ve been thinking about crawling under for 2 months. It’s due. It isn’t being driven but it needs and oil change.
Bring it over here. I did my wife’s Edge yesterday. Way easier then my truck.
Whooped Ol Grey over to Jonesboro and back. Thunderstorms going and coming. I am very impressed with the wet traction from the new Coopers and also hydroplaning resistance. Big long puddles on old state highway. I knew they would be good tho.
2 Italian tuneups on the way over and a big one on the way back (y) (y) (y)
Had a local company over here in AZ "Domed Numbers" make me some black and white 2&5/8's center caps. These are not vinyl overlays. They are a gel type overlay. Very happy with how they turned out. Flow nice with the black and white theme of my truck.
Did the throttle reset. Made a minimal difference.
Last blue oval to cover....steering wheel. Size was perfect, heat up a bit with blow dryer and it molds to the existing emblem nicely. Satin black with gloss white lettering.
