3521 - 3540 of 3544 Posts
185k mile service
Reactions: Nisco
Nothing. Absolutely nothing...
Top photo is of the D side cab damper, bottom photo is the P side, (after the damper rusted and fell off), ready to be fixed.
Put a new Motorcraft battery in 2days ago. I was running on the original 8 year old battery and constantly getting battery saver warning for the last couple months. Weird thing was it always started up fine with the exception of 6.8 volts cranking.
I didn’t have BCM reset but truck did sit for 31 hours untouched when I tested cranking power. Now 10.4 volts and no warnings.
185k mile service
Did you look into the pleats of the filter? Is that why it looks like that?
If your filter is coming out like that, I’d toss in the Motorcraft. The WIX did have a higher vacuum reading on my manometer, so it did not flow too well.
That is a wix... I just put in a new one , will have to keep an eye on it... get a motor craft next time
I did peek between the pleats, but can’t say that would attribute to all of the separation you see
2013 XLT 302A 145" Screw
I don’t know down here in Florida we have to worry about the kind of lug nuts we buy because of the salt air we have here. The open end style are not good because the salt can corrode the studs and freeze the nut on. At least that’s what I as told as I always put a little oil or something on them anyway…and on that note…Has anyone ever heard of lug nuts swelling? Took my truck in for standard rotate, balance, alignment check and they told me they recommended replacing all the lug nuts bc they were swelling. I have never heard of this…
Yep. Swollen lugnuts are a thing !
