201 - 220 of 245 Posts
Dropped off my 2015 at the dealership for the 100K service, possible master cylinder replacement (recall), front brakes and a seeping rear pumpkin. They said the pumpkin looks normal ... 1/3 of the entire pumpkin is damp. This is my last free maintenance from the dealership, trying to make the most of it.
100K miles is about 4 years including almost 9K in towing. The minimum goal is 200K out of this truck.
Cleaned
Reactions: Sirikenewtron
Used the winch today to move some poles into a vertical position ... when I put the winch back, find some wires frayed on the cable. Winch is used 2-3 times a month a minimum for the last 4+ years. So later today, I bought a new winch and installed it with the 11 year old.
You mean you bought a new winch cable/rope, right?
I was thinkin the same.
Actually no, did the whole thing! We were starting to have issues with the engage/disengage lever as well. It would not disengage despite working on it and soaking it for the last month. I would have continued working on it had I not found the frayed cable. My local shop suggested that I open the winch up to see if something was blocking the lever.
A new winch cable would have cost ~$140 plus installing my time installing it - never having done that before. But to do it, I need to disengage the winch, which I could not. For $290 out the door, I bought a new winch, all new hardware and with my sons help had it installed in ~30 minutes.
The truck and I had a long talk about it not having any more costly failures for a little while, I think it took it well
I hope you aren't offended if I say that if I were a truck, I'd be a little reluctant to sign that agreement with you.
However, at least I would know you can fix me, no matter whose fault it is.
Reactions: Arkansas Eco
Our relationship values transparency, I think it’s why we’ve lasted this long.
I actually drove it!
But only after trickle charging all night on "AGM" setting because the battery was as dead as a door knob. (wonder if the Ngauge or something else drained it? I admit it sat for more than a month)
Also updated the firmware on the Ngauge and WHALLAH, finally a legit Cac_T pid reading! Now my heat soak Temps are real just like everyone else's. Lol
Gonna grab me a new Intercooler. Can't let Meaz trick his truck out more than mine.
But did you get installed what you already bought?
I always recommend people swapping the motor while they have the intercooler out. Just saves some time.
Yikes 😳 Could be fun tho.
