1 - 20 of 42 Posts
Never saw this screen before. Stereo worked fine this morning. Got in this evening and it is stuck on that screen and no buttons including power button will work.
ANY HELP PLEASE !?
THANKS
Discussion Starter · #3 ·
OOOPS
Gadget Caller id Font Audio equipment Technology
Discussion Starter · #4 ·
Date on left and time on right and the time is froze also. Normally shows cell signal, battery state, temp.
Discussion Starter · #5 ·
Worked last night and been up all day.
Pull any fuses related to sync, APIM and audio. See what happens after.
Discussion Starter · #9 ·
Discussion Starter · #10 ·
It means your truck has expired, past its "use by" date, and it is time to buy a new one.
I gave er heck this morning uphill for a few miles so she might be a tad ticked. No pun intended !
Reactions: N4HHE
Discussion Starter · #11 ·
Reactions: Arkansas Eco
Discussion Starter · #13 ·
Welp all I did was go out and turn the key and Cody Canada is singing Sick and Tired 🤷‍♂️
Weird hope it stays working.
Discussion Starter · #15 ·
Thanks Y'all !
I had turned key off and on, on the side of the road a few times and nuttin !
I guess it had to be locked up and completely powered down for a while.
NEVER saw that screen before ever !
Strange.
I guess your APIM shuts down/starts up without you seeing that splash screen normally? I thought Sync3 showed that splash during both events.
Thanks Y'all !
Strange.
I went out to see mine. After sitting all night. Turned it on saw ford emblem on splash screen. Turned it off to check it again and get a pic of screen and now it doesn’t splash. Goes right to SiriusXM channel I was on. Maybe that screen only comes on after truck goes to sleep over night?
Discussion Starter · #19 ·
Time to upgrade to an 8"
The best IT answer is always shut it off and turn it back on again.
Yes and had done that several times.
I would actually like a new Alpine or Stinger widescreen !
1 - 20 of 42 Posts
